![]() | Home > Technical (L322) > Centre rear seatbelt removal |
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 ![]() ![]() ![]() |
You'll need to remove the rear seat and then take off the backrest cover to get to the seat belt retractor. Then take off the cushion cover from the base of the seat so you can remove the seat belt bolt that keeps the other end attached. |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
got it removed anyway. I just have a slight issue now. When I try to put back the seat into the upright position its locked. If I push the metal plate that locks the seat in with a screwdriver it works then. Is it possible I have disconnected a spring or something that is responsible for this or is it just stiff ? Current Vehicles :
