![]() | Home > Technical (L322) > Turbo's |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
My tdv8 has about 248,000 km. It's going well. However next service I will ask them to check the lower intercooler hoses for any signs oil is starting to bypass the turbo seal. ______________________________
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Seems to be a roll of the dice.
Proactively you can do something.
I hope you're right. My FFRRs been serviced every 10,000km, which is what gave me confidence in buying such a high mileage vehicle. ______________________________
I haven't stuck to an official service schedule in yonks! My daily donk gets it at between 4-6k mainly as I run it on some nasty fuel combinations but also as oil and filters are so cheap for it that 3-4 services a year are nothing in the grand scheme of it all and it's the banger car and the others don't get used anywhere near as much |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
The other common issue with them is a sticky turbo actuator if underused, it basically gums up with crap and goes stiff so you get an engine management warning on startup. This can be freed off with a wire coathanger and some wd40 then a spray of 3 in one oil. I have added this procedure to my twice annual clean and check as a preventative measure. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45 ![]() ![]() ![]() |
Hi Machinehead, could you offer some assistance as where to use the wire coat hanger to free off the actuator rod as i suspect mine is currently stuck on the nearside turbo? |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
I have the sticky turbo actuator issue with mine. Is there a write up anywhere on how to clean and lubricate? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Bump |
SveinHa Member Since: 22 May 2016 Location: Karm�y Posts: 36 ![]() ![]() ![]() |
Somewhere I read that when changing engine oil and only drain thru the most accessible drain plug, sludge will build up around the turbo drain pipe and eventually blow the turbo seals. Not sure how important this is but as long as the tdv8 have two drain plugs it seems wise to use both. "Plentraktoren/Garden tractor": 2008 L322 TDV8
Ive had a mad year so not been about much. The turbo is above the nearside diff. Its a pain in the butt to get to but.... if you put a hooked bend on a coathanger you can just get the bottom of the actuator rod looking forward from behind it.
