Home > Maintenance & Mods (L322) > Power Pack/Jump Pack.
Page 3 of 5 <12345>
^ it would also concern me that if indeed Chinese copies are being made available that the units are safe to use.
You just have to look at the recent Chinese copies of "Hoverboards" causing fires due to dubious quality lithium batteries and badly designed/manufactured circuit boards and chargers.
Be a shame to buy one of these things only to have it burn your house down or burn your car out.
Post #366345 10th Jan 2016 11:26am
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
for what its worth, the FLOUREON® T3 18000mAh is the real deal.
After spending all of 1 hour (felt like hours thou) on you tube and the internet in general, the FLOUREON kit is the real deal and not a copy made by my uncles and aunt's in the Motherland Very Happy
I've ordered today from Amazon.
I will do a review for the FF family in the next few days.
Post #366532 11th Jan 2016 2:02pm
Anyone bought one of these and had to use it in the present cold weather?
Post #368108 20th Jan 2016 4:25pm
rangeseb
Me!
Used once on Saturday morning.
as you've seen with my other post about my battery problems. Big Cry
it works that's all i can say.
I will do a review so everyone can have a read and see whats its like on a day to day basis.
Post #368111 20th Jan 2016 5:00pm
rangeseb
Also i know Duracell777 got one too.
Post #368112 20th Jan 2016 5:02pm
Duracell777
Hi
Have only used it to start a laguna 1.9dci which it did (from flat) and also charged my wifes laptop (from 50%) and kept it topped up for 7hrs with about 50% charge remaining in the pack - according to the blue LEDs.
RR battery is new so no probs here, yet Whistle Thumbs Up
When being charged, the unit stays cool. Thumbs Up
Post #368192 21st Jan 2016 3:35am
What does 'flat' mean ?
Does it mean the car would turn over but not fire - or completely dead so that when you open the door, the interior light doesn't even come on ?
Useful that t's able to run a laptop for 20 hours - or whatever that maths is - and if that's its primary purpose with the added benefit of maybe tipping the balance on a car that would almost start - then I can see the case for one.
I'm still sceptical about it's car starting abilities and buying one when that is your primary intention......
Post #368222 21st Jan 2016 7:44am
Duracell777
Sorry, to clarify.
Flat in this instance means ignition lights on but no attempt to turn the engine over.
Ignition lights go out when attempting to start and a single click from the solenoid.
I do have a totally flat battery in the garage but can't be arsed to connect it to check. More important things in life (at the moment). Smile
If it won't start a totally flat (no interior lights) battery then I am no worse off than if I didn't have it, but for £50, (loose change in FFRR ownership terms), worth a punt as it has many other uses, laptop supply being just one. Keeping my wife working at home when she left her charger at work was worth the £50 on its own.
You pays your money, you takes your choice Thumbs Up
Hope this helps Thumbs Up
Post #368245 21st Jan 2016 11:03am
Thanks Thumbs Up
Certainly worth considering - IIRC then I paid not far of that a few years ago just for a USB battery pack to charge my GoPro when out and about
So thought of in that context - with a potential benefit of a car battery booster - seems too be quite attractive
Post #368255 21st Jan 2016 11:41am
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
I bought one of the cheaper £40ish 32000mah portable power packs, 6 months ago from ebay, likely a Chinese copy.
It performed faultlessly until last week or so. I gave it heavy use, I would suggest around 35 jump starts on varying vehicles, everything being 3.0 or above. It started a 4.4 V8 M62 that had been left for 2 months, a TD6 and a TDV8. It would start a completely dead car, i.e. even the central locking was inoperable.
I used it on my preserved police vehicle, the blue lights had been used without the runlock system and was completely dead, started that no problem!
I, however, suspect it's continual use lead to its demise. It doesn't hold charge very well now. It will jump start one vehicle before requiring charging. I was very sceptical at first, but they really do work.
I have now invested in a £98 device, which appears visually similar but I know to be more durable.
For occasional use, the cheaper devices would work well, but for extended use I would advise the more expensive ones. I'll add the link to the one I bought later.
Post #368989 26th Jan 2016 7:12pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
These are the best I've used in 35yrs in car trade bar none and THEY do start 4-4 diesel from dead flat among other many many uses Thumbs Up http://www.johncraddockltd.co.uk/land-rove...torch.html
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #369020 27th Jan 2016 10:14am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
Bought a Floureon T3 18,000 mAh unit - from fleabay for £57 inc compressor
so far have only used it to start a fiesta that hadn't been started for 9 months, battery completely flat no lights on ignition, started it first time - quite impressed
intend to use it this weekend to try starting my mates TDV8 3.6 as his battery is knackered, only to test the unit , then he'll get new battery - will report back how we got on
just for info - decided to put the Floureon unit on charge in boot of my L405 , using the accessory socket that only comes live when engine running - thought that should keep it topped up,
BUT with it plugged in and charging it blocks the DAB radio signal completely Shocked the RDS radio still works fine
I assume the DAB reciever is behind the left hand side panel where the accessory socket is located and that the 12v cable being live blocked it - however didn't check to see if anything else was being blocked ie Sat Nav or BT
have now plugged it into one of rear accessory sockets DAB all working and unit charging when engine started
only telling this story as this caused me serious grief that the DAB had gone up the swanny and I would have to return to the stealers to repair - happy when I realised what was causing the problem Thumbs Up various other LR's this one is still the best
Post #376285 8th Mar 2016 9:55am
rangeseb
cheers philbathurst,
I completely forgot about the 12v port in the boot!!!! I've been charging mine with the rear 12v by the passengers seat.
Post #376289 8th Mar 2016 10:07am
Tang37
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Java Black
I have a snap on power 1700 jump pack and when my battery was dead I put it on and it jump my 4.4 v8 nice and easy went to get the battery checked out and it was gone so put a new one on and touch wood no more problems. Thumbs Up
Post #376568 9th Mar 2016 5:49pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Got the same pack but it WONT start a TDV8.
Post #376627 9th Mar 2016 10:50pm
Page 3 of 5 <12345>
