Home > Maintenance & Mods (L322) > FBH Success at last
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
FBH Success at last
Well with a lot of help from Ian at a company called 'Sub Zero'
Now this chap really knew whis stuff and had the FBH off the vehicle in about 10 minutes without even taking a wheel off he then put the diagnostics on on his test bench in his vehicle confirmed it was the glow plug replaced it with a new one and also all new gaskets/serviced it/cleaned some of the carbon build up out in the heater, connected it up to his mobile test bench and away she went , never been so glad to see smoke haha, fitted it all back on the FF Done 2 full test cycles full cycles and the cab reached 44 degrees (outside was 4 degrees).....heaven, All in took him about 2hrs tops worked without a breather or even a cuppa,
Ian is a very nice chap to boot and works on marine and plant and importantly is registered with Webasto if you look on their website yip can find his details if needed , I would thoroughly recommend him to you all.(and very reasonable rates indeed)
Main dealers quoted me £1200 for a new unit then labour to fit it Shocked , I tried at 4 other ' 4x4 specialists ' and none of them wanted to touch the job with a bargepole,
Just thought I would pass this on as I know several peeps on here are having probs and or given up with their FBH as I did ,I only wish I had found him earlier.
Now bring on the Cold mornings........it's already sitting on the Ctek charger (though the 2 cycles earlier didn't seem to bother it TOUCH WOOD)
Post #368114 20th Jan 2016 5:18pm
smighall
England 2005 Range Rover Vogue SE Td6 Buckingham Blue
Have you got a link to their website? struggling to find them on google.
Post #368117 20th Jan 2016 5:54pm
J evro
I just had his mobile number sorry,
Sure he won't mind me giving you it 07843 936155
Try Google Sub Zero Folkestone but don't think he's updated his webpage recently, goes by word of mouth mostly,
Also try Facebook ......Sub Zero
Smile
Post #368141 20th Jan 2016 9:01pm
smighall
This'll be the chap then http://www.subzeroac.co.uk/contact.html
Post #368142 20th Jan 2016 9:06pm
J evro
That's him
Ian Smith Smile
Post #368147 20th Jan 2016 9:31pm
dan_uk_1984
I've dropped him a message on FB as I'm interested in getting a petrol FBH retrofitted to mine.
Post #368302 21st Jan 2016 3:53pm
J evro
Not sure if he does that mate, but give it a go Thumbs Up
Post #368306 21st Jan 2016 3:59pm
Helios
Very interesting, thanks for posting
Post #368330 21st Jan 2016 6:22pm
