Home > Wheels & Tyres > Mixing tyre makes
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
Mixing tyre makes
I need 2 new back tyres and the two fronts are reasonably new conti cross contacts, I was thinking of putting Pirelli scorpions on the back instead of conti, any thoughts?
Post #368126 20th Jan 2016 7:21pm
not ideal but acceptable as long as the same axle has the same make/depths... ... - .- -.
Post #368134 20th Jan 2016 8:25pm
I would never do it again - having learnt the hard way- admittedly in a high performance car I was driving fairly quickly Whistle
Basically - well within the limits of grip, you're fine - but ultimately one set will give up before the other set - and you can't really predict which set that will be in all conditions - and then the car behaves unpredictably.
In my case, the rears gave up & the car just snapped into a spin - and I didn't think I was anywhere near the limit......
With a FFRR you're probably OK - and many people have cars with 4 different brands - but I would never do it again.
Post #368135 20th Jan 2016 8:31pm
Sandyt
+1 similar experience in an XJS few years ago ( well a lot of years ago if truth be told) lesson well learnt I now change tyres at 3mm and only replace 4 at a time
Post #370149 2nd Feb 2016 9:40pm
Wouldn’t surprise me one bit if it drove like a dog afterwards sir...
Change all four and offer the two Conti’s for sale? Is that an option?
Post #370190 2nd Feb 2016 11:41pm
Harris
Seems to be ok so far 😀
Post #371581 9th Feb 2016 11:04pm
so you put some pirellis on the back then? ... - .- -.
Post #371605 10th Feb 2016 7:08am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Nexens on the front a couple of years ago with contis on the rear. About to put Nexens on the rear because have had no bother at all in about 9000 miles with the ones on the front. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #371609 10th Feb 2016 7:44am
