Home > Technical (L322) > External Temperature Reading |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
It does seem strange how almost all car thermometers read artificially high at least by 1 or 2 degrees.I have a couple of more accurate ones at home and the usual hot or cold days when people say it is [x] degrees today after driving their car when I usually have to correct them ! |
20th Jan 2016 4:00pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Anyone got any idea why this AAT sensor has now started reading - 40.
30th Jan 2016 8:10pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
easy to check the wiring to the sensor as it sits behind the front grill. 3 screws to take it off and have a look. sounds like its open circuit. There is nothing that can't be fixed with a hammerππ
30th Jan 2016 8:22pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
If nothing has been disturbed then do a hard battery reset... Might just put things right? |
30th Jan 2016 9:25pm |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
Mine read -40 withe the sensor unplugged. |
30th Jan 2016 11:47pm |
Oups post by accident Eddie the eagle watch out π |
31st Jan 2016 1:20pm |
Hi chaps
31st Jan 2016 1:22pm |
Cheers Craig. Yep tried that. In fact it was working OK before I took the Battery off to charge it on the bench. I only did that because the car was not getting used much. I was getting between 20 to 23.5 mpg out of her on a steady motorway run to Wales and back at Christmas. Now it's down to 11.5 mpg. I know it may take a few miles to settle after a reset but not sure I can find Petrol stations close enough together to do that. LOL.
31st Jan 2016 11:00pm |
Pepi,
31st Jan 2016 11:09pm |
Cheers Declan have read your post with interest. Did you find a resistor that would give you a zero reading? Or any LR written calibration data. Saying what resistance the sensor should be giving. Also did you try a dead short test reading.
31st Jan 2016 11:18pm |
Hi Pepi,
1st Feb 2016 4:23pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Had something similar last thurs when I changed the battery. Immediately showed as reading minus 40c !! Drove around for a couple of hours and the temp returned to what it should be, dropping a few degrees at a time. |
1st Feb 2016 5:19pm |
Thanks Declan
1st Feb 2016 7:04pm |
Thanks for that it will be good to see if it will sort it's self on mine.
1st Feb 2016 7:06pm |
