Home > Technical (L322) > External Temperature Reading |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
The grill ambient air temperature sensor should only be used for the air con/FBH/Heated screen/ice warning reference and display on the instrument info panel.
2nd Feb 2016 9:24am |
If you disconnect the battery it will indeed lose the fuel trim numbers and will need to be relearned, it won't relearn them all until you go between every load and rpm combo in closed loop. As a guide I've always taken a tank of fuel as enough to say it's relearned back to where it should be. Having said that it shouldn't make a huge difference to the fuel useage unless there was something wrong and it was compensating with fueling (such as an air/vacuum leak).
2nd Feb 2016 12:04pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Yep sound advice and I am not that anal about consumption figures.
2nd Feb 2016 1:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8178 |
Pepi, the wire goes into the loom that picks up the left hand fog light then into the engine bay beneath the headlight, it could be chaffed somewhere and shorting the fog light and temp sender... you can get to most of it by removing the front undertray and left wheel arch liner.... Pete
5th Feb 2016 12:38am |
