Home > Technical (L322) > L322 2010 climate control auto setting |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
try 'memorising' the key to the seat ... ... - .- -.
18th Jan 2016 8:32am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Try a battery reset... |
18th Jan 2016 8:51am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
not to jump in on this thread but mines the opposite - 2010 VSE and I turn auto on but each time I turn the car on it is not set to auto.. Ash
18th Jan 2016 3:20pm |
try my suggestion Ash, i know when i changed my key fobs to make sure the battery was charged up , the radio settings and heating controls were different....worth a try.. ... - .- -.
18th Jan 2016 3:23pm |
Ash
18th Jan 2016 3:24pm |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
My 2010 exhibited the same behaviour. Nearly always went into 'Auto' when starting. Sometimes it would remember if it was re-started after a short time, but more often than not it went into 'Auto'. One of several irritations. |
18th Jan 2016 4:27pm |
d.milner01 Member Since: 17 Jan 2016 Location: Cv130lb Posts: 4 |
That's great advise I'll try it and report back, how do carry out a 'battery reset'? |
18th Jan 2016 7:22pm |
Just one more thing to add (may throw some light on it) it had a new battery before I took delivery? |
18th Jan 2016 7:24pm |
battery reset details are in the wiki.. ... - .- -.
18th Jan 2016 7:32pm |
Checked the spec in the manual and there's no reference to memorising a key to the seats, heating..... The Only the seat recall is on the side of the seat as hard buttons, my old sport had a memory from the key I can't believe this car 2010 vogue doesn't have this feature!
18th Jan 2016 8:18pm |
with the key you use all the time, set the heating etc to what you want and then press memory save on the side of the seat...
18th Jan 2016 8:56pm |
not tried it but you could be on a winner here Stan... I seem to remember that the key memory also retains the stereo volume and other settings for that user..
18th Jan 2016 8:58pm |
it happened to me Ash, when i used my spare key for the first time it moved the seat to a different position and the radio stations were from the area where the car was previously...i'm also sure the heating controls went haywire as well.. ... - .- -.
18th Jan 2016 9:48pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I've had a faff with the memory settings with both keys to move the seats and other stuff. I've even put one key in the freezer for a short time while I try to set the memory for the key in hand (1) and then swapped the keys around with one in the freezer and set the memory to the other key (2). Opening the car neither key will move anything, I have to press the numbers on the side of the driver's seat to move everything. The dealer took a look at one point and when you read the manual it seems to say it should do what I have tried to do but they say it won't. A bit like all the other things it says it should do but doesn't.
18th Jan 2016 10:18pm |
