Home > Technical (L322) > L322 2010 climate control auto setting
d.milner01
I've just purchased a 2010 l322 and everytime I get in and start her up the climate control is set and on in the Auto mode, why? I want it to remain in the last position I left itin when I last drove the car. This is my 7Th RR I've never had it before (last one was a sport) and it doesn't happen on any other car I've driven.
Any help welcome - Thank you!
Post #367675 17th Jan 2016 10:46pm
try 'memorising' the key to the seat ... ... - .- -.
Post #367707 18th Jan 2016 8:32am
Try a battery reset... Thumbs Up
Post #367714 18th Jan 2016 8:51am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
not to jump in on this thread but mines the opposite - 2010 VSE and I turn auto on but each time I turn the car on it is not set to auto.. Ash
2016 SDV8 AB
Post #367787 18th Jan 2016 3:20pm
try my suggestion Ash, i know when i changed my key fobs to make sure the battery was charged up , the radio settings and heating controls were different....worth a try.. ... - .- -.
Post #367789 18th Jan 2016 3:23pm
comports
Thumbs Up Ash
2016 SDV8 AB
Post #367791 18th Jan 2016 3:24pm
nobbyclark
My 2010 exhibited the same behaviour. Nearly always went into 'Auto' when starting. Sometimes it would remember if it was re-started after a short time, but more often than not it went into 'Auto'. One of several irritations.
Post #367808 18th Jan 2016 4:27pm
d.milner01
That's great advise I'll try it and report back, how do carry out a 'battery reset'?
Post #367843 18th Jan 2016 7:22pm
d.milner01
Just one more thing to add (may throw some light on it) it had a new battery before I took delivery?
Post #367844 18th Jan 2016 7:24pm
battery reset details are in the wiki.. ... - .- -.
Post #367847 18th Jan 2016 7:32pm
d.milner01
Checked the spec in the manual and there's no reference to memorising a key to the seats, heating..... The Only the seat recall is on the side of the seat as hard buttons, my old sport had a memory from the key I can't believe this car 2010 vogue doesn't have this feature!
Checked over Heating and Ventilation in handbook and there's no reference to it resting to auto everytime you start the car again it's really frustrating!
Post #367854 18th Jan 2016 8:18pm
with the key you use all the time, set the heating etc to what you want and then press memory save on the side of the seat...
Post #367856 18th Jan 2016 8:56pm
comports
not tried it but you could be on a winner here Stan... I seem to remember that the key memory also retains the stereo volume and other settings for that user..
Will give it a bash.. Ash
2016 SDV8 AB
Post #367858 18th Jan 2016 8:58pm
it happened to me Ash, when i used my spare key for the first time it moved the seat to a different position and the radio stations were from the area where the car was previously...i'm also sure the heating controls went haywire as well.. ... - .- -.
Post #367869 18th Jan 2016 9:48pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I've had a faff with the memory settings with both keys to move the seats and other stuff. I've even put one key in the freezer for a short time while I try to set the memory for the key in hand (1) and then swapped the keys around with one in the freezer and set the memory to the other key (2). Opening the car neither key will move anything, I have to press the numbers on the side of the driver's seat to move everything. The dealer took a look at one point and when you read the manual it seems to say it should do what I have tried to do but they say it won't. A bit like all the other things it says it should do but doesn't. Whistle
Oh and the heater settings......... Well I've tried all things with that and it won't give warm air out the centre vents but gives cold air out, only way to get the desired air flow where you want it is to set it every time you get in. Rolling Eyes
Post #367876 18th Jan 2016 10:18pm
