Home > Maintenance & Mods (L322) > Headlights stuck on dip? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
When selecting main beam there is no discernible change in the output from the Xenons however the inboard light comes on and this provides high beam. I'm not sure weather on not the xenons should change, I think and have read on here, that they should but mine don't seem to. Another feature is that when first switching on the are high and bright then stabilise to a less bright setting anyone else lights behave like this? Geoff |
17th Jan 2016 9:50pm |
sorted - nowt wrong Geoff |
18th Jan 2016 2:30pm |
So can I replace my mains with these to get them a little bluer?
18th Jan 2016 2:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
you can get even cheaper on ebay Geoff..around £8 a pair for white type jobbys... ... - .- -.
18th Jan 2016 2:46pm |
or what about led/smd/crees ? ... - .- -.
18th Jan 2016 2:48pm |
Thanks Stan.
18th Jan 2016 4:44pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
LEDs are plenty fast enough, but they would not match up with the correct focal point designed for a narrow filament.
18th Jan 2016 5:24pm |
tbh Geoff i tried leds , not that they didnt work , they did but one had a dry joint ...so some cheap ebay 'white' light type went in and have been there ever since...
18th Jan 2016 6:24pm |
