![]() | Home > Technical (L322) > Is my FSR failing or failed? |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
I know it was early when I posted but anyone? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
have you done a search ? ... - .- -.
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
got no idea what FSR is but my battery drain over night after much investigation by LR was down to the fact the park heating/cooling remote receiver was staying live and not going to sleep. - they swapped out the module (in the boot) and hey presto. |
I don't know if this helps but if I turn my heater/blower switch off and then lock the car the blower doesn't restart itself when I unlock the car or even turn on the ignition. I have to physically turn the knob or press the button to start the fan inclusding orange indicator lights. |
the problem i have is the heating/blower comes on sometimes when i get into the car to start up even if i turned it off on my last drive.
Anyone>?
**update**
Cheeky bump.....
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
The FSR needed to be replaced on my 2004 car, but the symptoms were not as you describe (it was just a case of no heat into cabin, sometimes one could 'trick' the car by changing the area to be heated and then going back to the original choice once the hot air had come on).
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
Hi rangeseb
Thanks guys for the comments!
docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48 ![]() ![]() |
Hi,
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
New light on old topic. Latest baby playing up! 2012 4.4 Westminster
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi Arbukckle,
