Home > Maintenance & Mods (L322) > Bespoke Rear Number Plate |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
that plate looks too big imo, the size i thought was 21'' x 6''
17th Jan 2016 3:14pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
Yes bigger than std so no gaps either side and little top or bottom. Many thanks
17th Jan 2016 3:17pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Aesthetics aside, I'd be worried about the larger size creating a dirt trap. The smaller plate allows hosed water to sluice behind and a small bit of movement and flex to dislodge any nasties. The larger size also prevents air circulation much more than the standard size. |
17th Jan 2016 3:58pm |
Good thinking, me also so there is circa 5mm at the top and 2mm either side so all fluids etc are fine Many thanks
17th Jan 2016 4:02pm |
If you use the correct pads to stick the back plates down getting water around the back is no issue.
17th Jan 2016 11:20pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
When I bought my car the n/plates were stuck by pads. A couple of months later (July time), I was caught in heavy traffic stop / start moving slowly with the sun behind me. Unknown to me the rear plate fell off I only realised it back at the house .
18th Jan 2016 1:57pm |
Good info there from all.
18th Jan 2016 5:33pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Is there not a legal stance on plate size, there seems to be a rule for every other aspect of displaying number plates ! Is this where I put the car details and a bit about myself ?........ |
19th Jan 2016 9:25am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I don't know about a legal size requirement for number plates but I do know the OP's number plate isn't legal insofar as it doesn't display the manufactures name and postcode and the relevant BS number.
19th Jan 2016 9:35am |
There is only a legal rule re minimum size and font details.
19th Jan 2016 9:48am |
You might consider it trivia but unfortunately the rules have changed recently and the number plate is now part of the mot. According to my well informed mot tester your plate is certainly a potential fail. |
19th Jan 2016 10:08am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i dont want to 'handbag' the issue, but......not only is ScottyRR's plate mis-spaced, 2. it has a car make and not a uk/euro flag, 3. it has not got the plate makers postcode, 4. it has no BS symbol. (british standard) -and 5. they spelt 'autobiography' without the 'H' so, the only thing that's good for it, is, - its not upside down!
It is trivia even petty, just use a sensible mot tester who does all the important things, when was the last time people had there spare wheel checked, very few no doubt.
19th Jan 2016 10:18am |
Spare wheel isn't and has never been a testable item under the MOT. |
19th Jan 2016 10:24am |
