![]() | Home > Maintenance & Mods (L322) > Adjustable Tow Bar ? |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Yup: VUB000720 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Also known as a "Farmers Hitch". They sometimes come up for sale on the forum. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
I have noticed the same, it is slightly low for a trailer to sit totally level, but said the adjustable farmers hitch will sort it. It fits into the armature in place of the detachable receiver so you don't need to change the whole caboodle just remove the pun and knock out the detachable receiver and put the farmers in its place. It is also a removable part too with a pin and clip to retain it. |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
How low is the trailer though? Trailers are supposed to have a slightly nose down attitude, it helps stability when towing. (according the Ifor Williams' guide to towing)
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
I bought mine from PF Jones via ebay. It came with a towing ball fitted to the towing plate, a carry case for it, a 7 pin prewired socket and mounting plate (XPF027B2M).
FullFatDunc Member Since: 16 Aug 2015 Location: South Somerset Posts: 65 ![]() ![]() |
Thanks everyone
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
There are actually 3 different versions of the farmers hitch - I've had 2 of them - due to me leaving one in my shed in France and coming home without it |
What was the socket for? That should already be attached to your main towing armature under the car.
The PF jones one i linked to is the one with the pin, rather than a bolt. incidentally the middle hole on the hitch is the standard height (which all modern trailers are built to), it's about the same as the quick release ball height. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Got one from Gumtree, unused £40. |
If you're removing it when not in use, then I also recommend a KYB000011 plug for the square armature - available from Dan |
Zirconblue
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
The ffrr hitch is too low full stop, and there is no height difference between the swan neck and the 'Multi hole' farmers hitch in height. For some inexplicable reason the the adjustable hitch goes down rather than up |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I had one of those, took me all day to get it off. Had to use a bottle jack! Against the armature, so yes, put a bit of grease on it. I thought latter if I drilled the shaft, , it could go in upside down. I got myself a swan neck, and now I don't plough the car parks or soft grass verges. As I've said before, you can buy 50mm box section 5mm thick, and make your own, via eBay... (with the help of an arc welder). |
