The car has finally relented and had a dicky fit......after 8 months of nothing going wrong, I popped to the supermarket earlier today, car started at home fine and no problem, parked it up on the supermarket carpark and when I got back in was met with a series of faults.
EDC, ABS, air suspension lowered for safety, and no lights on the selector switch, EPB malfunction.....and so on.
Now I know that this is usually a voltage issue, and the car hadnt been driven until yesterday, where it did a decent run down to tamworth and back, 1/2 hour each way, no problem or faults, I haven't got my meter with me at the moment so i can't check the voltages, but all faults have gone away, and the suspension cycles up and down normally, any clues what I should be looking for apart from the usual battery reset and make sure its charged?
I left the car for 10 mins for it to shut down and the faults have disappeared, now replaced with Service Required which it isn't as it was apparently serviced last April by then MD before i bought it at 32K, now on 41K, so should not need a service for at least 3 months or 7K? There is nothing that can't be fixed with a hammer😜😜
