Home > In Car Electronics (L322) > Dashboard illumination
idrawcad
United Kingdom 2003 Range Rover HSE 4.4 V8 Alveston Red
Hi
I have a 2003 FF. The bottom screen of the info centre , below the odometer, that shows all the info when you press the left hand stalk, is only now illuminated on the right hand side, is this an easy fix?
Thanks My Motto: If you are going to have one, have a BIG one!
Post #365817 7th Jan 2016 9:52am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi idrawcad,
I'm afraid it's a dash off job to access the back of the speedo, they are twist and pull . There's 5 of them. I changed mine to led.
The direct replacement bulbs are R509TBE beige base. The led's I used were T5 12vB8.5d. Slightly bigger and protrude a little further out of the back, but still ok to fit. They come with the little metal tangs straight so you need a small pair of pliers to bend them down, just copy the ones you take out if you go the led route. And as all led's they need the correct polarity, so fit and check before assembling the dash back together.
There are quite a few how too's on you tube powerful uk is one.
Hope it helps. Greg.
Post #365890 7th Jan 2016 6:53pm
