Home > Technical (L322) > Glovebox opening
proser
Glovebox opening
To open the lower glovebox I have to give the drop down door a firm tap before the switch will release the lock. The upper one works fine from the switch.
Anyone had this and what was down to resolve it.
TIA Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #364818 1st Jan 2016 7:32pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
It may need a slight adjustment Orc you need to take the trim off underneath it to get at the bolts but it's ages since I done it L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #364826 1st Jan 2016 8:11pm
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Lower glove box??? That's a new one on me, I haven,t found that one yet. Share the secret please Bow down
Post #365601 6th Jan 2016 10:32am
the 2006 my's onwards have a top and bottom glovebox...the top one houses the cd changer and has a very small space to the right of it.. ... - .- -.
Post #365606 6th Jan 2016 11:06am
Chasazim
Thanks Stan, too many little hideaways are a waste of space, my 2004 is as flash as I will probably get so I will avoid a lot of thee problems I see other forums. Still lovely Lady though. Thumbs Up
Post #365609 6th Jan 2016 11:21am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I have to hit the lower glove box anywhere from 1-5 times for it to release. Top one releases first push. One of those quirks...I'm sure it can be fixed but haven't messed with it. Not sure if the issue is with the button or the release mechanism inside the glove box. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #365631 6th Jan 2016 1:21pm
Duracell777
My small space is full of 'venture cam'
Have same issue with lower box going to have a look tomorrow.
Post #365762 6th Jan 2016 9:39pm
proser
glad I'm not the only one. It may well be the weight of the glovebox putting pressure on the lock mechanism. Regards
Mark
2012 Westminster
Post #365765 6th Jan 2016 10:00pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
You have to tap it in ?
As if you're pressing in where the latch is before the latch opens ?
My lower latches open fine and the weight of the "lid" opens it .
So as suggested it I think yours needs adjusting .
Not got the same smooth operation with the top one though , you have to hook fingers on that and pull it down .
Not that we use it since the cd changer broke ) Laughing
Post #365789 7th Jan 2016 1:21am
horse86
The top one I tap the button once and it unlatches...then I have to hook my finger on it yo pull it down.
Bottom I have to tap the button anywhere from 1-5 times and once it finally unlatches it drops by itself due to weight. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #365860 7th Jan 2016 1:48pm
Duracell777
Hi all
Have just had a look at my glove box. took several taps to open it.
Check that nothing has fallen behind the box over the back edge. behind where the elastic strap is.
I found a small notebook {not the computer type) and a pack of "post it" notes.
After removal, the box now opens with a gentle touch on the button and the lid falls gently open. Very Happy
You never know it might be something as simple with yours.
Andy
Post #366681 12th Jan 2016 2:31pm
horse86
Can you lift up and out (by the hinge) on the glove box like most other makes to remove it and see if anything is jammed in behind? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #366690 12th Jan 2016 3:25pm
Duracell777
~Don't think its that easy to remove.
I was able to get my hand over the top at the back and remove said items.
I think you should be able to feel if something is there, although a pen or sutch like might be more difficult to detect.
Andy
Post #366705 12th Jan 2016 4:00pm
Duracell777
Had a closer look at glove box as needed to get to fuse box. There is a retaining clip on the side of the glove box (nearest centre console) that you just have to squeeze gently (towards the box) and the box will lower giving access behind.
Post #368193 21st Jan 2016 3:44am
horse86
thought so....most do that. I haven't had a chance to dig behind mine but will try this weekend. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #368270 21st Jan 2016 12:30pm
