Home > Technical (L322) > Boot Seal Replacement |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Is this a DIY job? Or should i take it to an indie??
5th Jan 2016 11:40am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35366 |
yes its a diy job, have a read here,
5th Jan 2016 11:50am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
basically yes it's a main dealer part.
5th Jan 2016 5:13pm |
So given the cost of a new seal 80! I am going to try with a tube of the silicone as per http://www.fullfatrr.com/forum/topic30015....=boot+seal
11th Jan 2016 1:29pm |
have a look at your existing seal closely. Mine was rotten around the top corners, if it's as bad as mine was (and mine wasn't leaking that badly), then i doubt it's worth bothering with sealant, and if you do use sealant, then if it doesn't you've got an awful mess to clean up to fit the new one.
11th Jan 2016 6:46pm |
Your where right, went to add the silicone and the top left corner is pretty much disintegrated |
13th Jan 2016 6:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
There is also a putty type sealer inside that never dries that seals the rubber to the bodywork... You won’t get that on a non genuine part sir |
13th Jan 2016 11:26pm |
I assume getting one from Dan will have this.. |
14th Jan 2016 8:30am |
Got the new seal from Dan, any tips on fitting??? |
21st Jan 2016 1:48pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Remove the old seal and any lumps of dried mastic and clean mounting flange around the tailgate opening with Meths.
21st Jan 2016 3:44pm |
great thanks for the tips... |
21st Jan 2016 3:52pm |
