![]() | Home > Maintenance & Mods (L322) > Power Pack/Jump Pack. |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
As some of you are aware i am having a few on/off problems with my FF.
im picking this as its has a charge cradle and will be easy for the Wife to use. Is there another Jump pack/power pack that you guys have and would recommend? Thanks |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
I to use the Clarke heavy duty pack. To heavy for most females, |
It weights 17KG - so it is a bit on the heavy side.
Just had a thought - I had to jump start a customers Merc estate (dont ask me what it was but it was massive!!) He had air in the fuel supply and it took about 5 mins of turning over in total before it fired up - It was still spinng over nice and quickly so I gues it does not need a charge after each start..
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
It depends how good / permanent a solution you want
That Clarke's 4000 looks the stuff! plus its cheaper than the one i want.
Hairball Member Since: 11 Jul 2014 Location: Leicester Posts: 67 ![]() ![]() ![]() |
Cheaper here http://www.tool-net.co.uk/p-333053/clarke-...wwodLd8KQw |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
We use a tiny Anti-Gravity Battery for jump-starts.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I've had one of these for years.
that Micro-Start XP-10 is nuts!
No issues for your wife to carry, either.
The Mirco Start unit isn't cheap.
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
Just to add to the mix, I bought one of these
