Home > Technical (L322) > glovebox 50 amp fuses .. HELP! |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
The 2004 must differ a bit in its fuses the only 50amp fuse in the glove box of mine is a spare. The four large fuses to the right in mine which is a 2009 are 30 and 40 amp fuses for engine fan braking and such like.
31st Dec 2015 4:16pm |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
Hi thanks for yous quick reply. There was a spare 50 amp above the 4 50 amp fuses and there was nothing on the card on the flap also there's nothing in the manual either. I had a fault code for electric cooling fan in the pcm so that would make sense but then again the smoke was coming from around the bulkhead so unless a wire has shorted somewhere then may not be. I usually enjoy fault finding but when it's my own car it's a chore ! |
31st Dec 2015 4:32pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
It's your electric cooling fan in front of the radiator - it's all that fuse does. I expect your fan motor is seized, the computer spins the fan for a few seconds as a test, at which point the fuse blows.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
As above but instead of just putting a replacement fuse in to see if anything happens after disconnecting the fan motor I'd be inclined to test the output of the fuse position for a short to earth. It's always possible the fault is a cable shorting to earth. You really do not want a cable fire on an L322. |
31st Dec 2015 5:04pm |
Yeah I will do as suggested! Thanks for the help I will post up if I find anything other than a seized up fan! |
31st Dec 2015 5:15pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
The mirrors are controlled via a brown really looking controller, as far as I remember
31st Dec 2015 5:27pm |
Hairball Member Since: 11 Jul 2014 Location: Leicester Posts: 67 |
Hi im in leicester also where abouts are you based |
1st Jan 2016 3:39pm |
Live in loughborough, work in sileby! |
1st Jan 2016 4:38pm |
