Home > Technical (L322) > glovebox 50 amp fuses .. HELP!
ptaroni
hi all, i am trying to find out what the 50 amp maxi fuses are for in the glove box fuse box. basically i have recently bought a 04 plate l322 td6, amazing car and surprising everything works apart from the folding wing mirrors. basically i have checked every fuse i could find and found a 50 amp fuse blown the one closest to the smaller fuses. i put a new fuse in and within a couple of seconds there was an really bad electrical smell and a very large amount of smoke from under the bonnet. I immediately pulled the fuse out and the smoke finally cleared. i myself am a mechanic and quite skilled at electronics but cannot find anywhere on which circuit this fuse protects. if anyone can help me out i will be incredibly grateful as i have a place to start! also if anyone close ever needs any help with diagnostics, mots and work i will always help anyone out! thanks in advance!!
Post #364667 31st Dec 2015 4:08pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
The 2004 must differ a bit in its fuses the only 50amp fuse in the glove box of mine is a spare. The four large fuses to the right in mine which is a 2009 are 30 and 40 amp fuses for engine fan braking and such like.
Wish I could be more help, I am assuming there is nothing marked on the back of the fuse panel for them? mine tells me what they all are. That was not meant to be patronising btw although I admit it was a rather obvious question. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #364669 31st Dec 2015 4:16pm
ptaroni
Hi thanks for yous quick reply. There was a spare 50 amp above the 4 50 amp fuses and there was nothing on the card on the flap also there's nothing in the manual either. I had a fault code for electric cooling fan in the pcm so that would make sense but then again the smoke was coming from around the bulkhead so unless a wire has shorted somewhere then may not be. I usually enjoy fault finding but when it's my own car it's a chore !
Post #364672 31st Dec 2015 4:32pm
Zirconblue
It's your electric cooling fan in front of the radiator - it's all that fuse does. I expect your fan motor is seized, the computer spins the fan for a few seconds as a test, at which point the fuse blows.
You can unplug the fan and refit the fuse to prove the fault.
Download the RAVE CD, it contains all the factory workshop manuals for your car. it's in the wiki i think
Post #364673 31st Dec 2015 4:32pm
As above but instead of just putting a replacement fuse in to see if anything happens after disconnecting the fan motor I'd be inclined to test the output of the fuse position for a short to earth. It's always possible the fault is a cable shorting to earth. You really do not want a cable fire on an L322. Thumbs Up
Post #364682 31st Dec 2015 5:04pm
ptaroni
Yeah I will do as suggested! Thanks for the help I will post up if I find anything other than a seized up fan!
Post #364683 31st Dec 2015 5:15pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
The mirrors are controlled via a brown really looking controller, as far as I remember Shocked
Get a replacement and they should start working again so long as the mirror motors are okay. Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #364687 31st Dec 2015 5:27pm
Hairball
England 2006 Range Rover Vogue TDV8 Java Black
Re: glovebox 50 amp fuses .. HELP!
Hi im in leicester also where abouts are you based
Post #364796 1st Jan 2016 3:39pm
ptaroni
Live in loughborough, work in sileby!
Post #364800 1st Jan 2016 4:38pm
