Home > Technical (L322) > 4.4 v8 head gaskets |
Hi,
16th Nov 2010 5:11pm |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
thanks for the response dan, i will know more when i collect the vehicle atthe weekend- it has been diagnosed by landrover dealership as head gasket failure- still runs to move around etc. will update once collected. |
17th Nov 2010 8:59am |
Definitely verify for yourself - The PCV hoses fail around 50K so there have been instances of these failing within the warranty period. This results in the LR garage replacing the HG under warranty, but at the same time they throw new hoses on - so the problem is fixed. But the problem is chalked up to the HG. |
17th Nov 2010 9:27am |
thanks dan- very imformative- i will check that out prior to any work being unndertaken! |
17th Nov 2010 2:58pm |
Dan,
20th Nov 2010 7:33pm |
The coolant temperature should be around 100C (undere pressure it doesnt boil) You can test the thermostat in a pan of water on the hob - it may or may not have an openning temperature stamped on it. Put it in some water bring it to the boil with a thermometer in there to verify the temperature it opens. Or if it opens before the water boils then it's OK.
20th Nov 2010 7:40pm |
thanks dan- that was my intention to whop it out and see if it still opened in boiling water- will try tomorrow all being well- yes bought it very sensible money! enough in there to hav ethe lump replaced....if required- i hope not! |
20th Nov 2010 7:49pm |
had the stat out yesterday- bit unusaul it appeared to have an electrical connector on the housing?? anyway, looks like a duff stat as itfailed to open when the water in the pan was boiling....will order one and get it on next weekend. |
22nd Nov 2010 10:47am |
The Thermostat housing contains a heater so the ECU can force the thermostat open in anticipation of high load - for example if you boot it whilst towing up a long hill, the ECU will immediately predict increased cooling will be required so heats the stat to open it fully, rather than waiting for super hot water to make its way all round the engine and then to the stat. Clever stuff. |
22nd Nov 2010 11:36am |
ahh! indeed very cleaver stuff- thaks for clearing that up dan |
22nd Nov 2010 1:09pm |
