Home > General > 6 months in - How long before the problems started?
pld118
Had ours for 6 months now and it has been great. Hassle free. Actually, as you would hope for... A pleasure to have Thumbs Up
Compared to our last one (pictured) which was exactly the opposite:
Maybe an age and mileage thing too of course (because the last one - nice and documented to the hilt though it was - it was over twice the age and mileage)?
Post #362854 19th Dec 2015 5:12am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Could it be an age thing? I've always thought the best car to buy is the one furthest into its production life with the ideal being the last one before being superseded by a new model. This is based on nothing more than the thought that, as the production run progresses, more kinks are worked out and processes and parts become more refined, being developments of the originals. Probably naivety at it best/worst on my part.
Post #362856 19th Dec 2015 7:08am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I think that makes perfect sense Giant.
Run out models also get the parts bin thrown at them so the specs are normally that much better. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #362858 19th Dec 2015 8:00am
Lost for Words
It's amazing how one car can be so different to another of the same in terms of reliability. Some have no end of trouble, yet someone else will own theirs for years and years without a single issue. Servicing and maintainence goes a long way, but I suppose you can never eliminate pot luck in it's entirety.
Generally, that's sound logic, but sometimes MY differences and improvements can reverse/change it etc. (D3 is a strong example). Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #362880 19th Dec 2015 10:23am
had mine for over two years now and no problems...some pre maintenance oils have done by the craig-meister and there are a few track arms that will be replaced next year, other than that im very happy..
i need to thank you agian Ryan for buying the cardiff FF before i got to it Mr. Green Wink ... - .- -.
Post #362904 19th Dec 2015 11:55am
CS
Based on my 2012 WM I agree about the spec, but am less sure about the problems side - I bought mine (an ex demonstrator) aged eight months and with <5000 miles, but needed a new gearbox after eight days and made 22 warranty claims in the remainder of the three year warranty, a mixture of corrosion, build issues and electrical failures.
It's still the best car for my needs and I hope it will settle down and be less trouble in future. Only Range Rovers since 1988
Post #362906 19th Dec 2015 12:00pm
pld118
You're welcome Stan, anything to help Laughing
Post #362909 19th Dec 2015 12:43pm
steadyaway
Had mine just short of a year. So far only the ignition switch has failed. Although it seemed to work ok after I stripped it and sprayed it with WD40, I opted to change it as a precaution. So far that's the only issue but with 130k on the clock I know some mileage related issues are bound to surface eventually. As the car was a Landrover management car for the first 3 years I'm hoping that all the other stuff has been done already.
Post #362976 19th Dec 2015 9:51pm
Had mine a year this month! & i know i do very little milage but only had the usual broken wire on the front strut issue & a manifold sensor...
I would forgive her most problems though as she is ssssooooooooo lovely to live with Mr. Green
Post #362988 20th Dec 2015 12:58am
pld118
Aye, maybe a bit of luck of the draw too (some great, others not)... What's 'the usual broken wire on the front strut issue' please?
Post #363009 20th Dec 2015 6:21am
Eight years and two L322's in and nothing much to report apart from a front air spring and compressor on the first one and that was done on the warranty , it doesn't have to be all doom and gloom Very Happy 2008 MY Supercharged
Post #363014 20th Dec 2015 8:12am
The usual “active dynamics fault” on the dash Ryan... Leads to a broken wire under the cover to a front strut... Well documented on here Whistle Happens to most 09>MY’s sooner or later Rolling Eyes
Post #363036 20th Dec 2015 11:26am
pld118
Post #363043 20th Dec 2015 11:55am
Mr Tee
Mines just flashed up with that fault, kit from Dan to replace.
Post #363067 20th Dec 2015 2:13pm
steptoe
The Mk2 of any model is the one to buy...
The Mk1 is the test model.
The Mk 2 has the problems sorted.
The Mk 3 and onwards is when they start to cut production costs.
Very Happy
Post #363073 20th Dec 2015 2:28pm
