Home > Maintenance & Mods (L405) > condensed front headlight, need help please |
Pixelpower Member Since: 16 Jul 2014 Location: Droitwich Posts: 203 |
Done 10k in mine and never had that problem |
18th Dec 2015 7:11am |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 |
States in handbook that condensation may appear at times, my previous one did it occasionally, my new one had done it once... |
18th Dec 2015 7:24am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Set the headlights to manual and leave them on your next couple of trips. The bulb heats the air inside the case and the condensation goes. It normally appears after vigorous jet washing or if the vehicle has been standing for a while.
18th Dec 2015 7:53am |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
i have this sometimes... All my spelling errorz are belong to me!
18th Dec 2015 9:37am |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 |
Have had it on other cars but not on this one yet. Wouldn't be worried though |
18th Dec 2015 9:44am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Not heard of it on Rangies. On Astons it is very difficult to shift and can cause the lamp interior to discolour. Keep an eye on it. Not noticed it on my L405. |
18th Dec 2015 6:54pm |
rrguy Member Since: 17 Dec 2015 Location: london Posts: 10 |
Thanks everyone for your kind reply.
21st Dec 2015 3:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8248 |
Sounds to me like the seal has gone and water is sitting in the bottom where you can't see it, turn the light on and the heat will evaporate the water and fog up the light... Check that the plastic waterproof cover you remove to change the bulb has been fitted properly as that could be the cause as well... Pete
21st Dec 2015 3:32pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Hay lands is right. The seal. You turn on the light and it gets hot, so the air in the housing gets hit, pressure increases and the air escapes through the seal. When the lighters turned off, everything cools, down, pressure now drops, and the moisture is sucked right into the housing making it worse each time. Hopefully a new seal doesn't mean a whole new light assembly. Good luck. |
21st Dec 2015 11:16pm |
