Home > Maintenance & Mods (L322) > 2007 - 2012 soundproofing differences |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2474 |
I have BFG ATs fitted to my 2012 and need to cut down the noise/reverberation from the front tyres on some surfaces. The rear was fixed with stick-on similar to Dynamat lining the spare wheel well but I suspect the front guards are vibrating as they have an empty sound when tapped, unlike the dead sound from the doors. Noise from the 4.4 TDV8 is not an issue for me. |
17th Dec 2015 7:08am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
these will help you in your quest Ian,
17th Dec 2015 8:34am |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
Thanks for the links Stan .
17th Dec 2015 12:44pm |
i'm surprised that your engine noise is a problem, mines a 4.2 as well and the noise is acceptable.. ... - .- -.
17th Dec 2015 1:18pm |
It's probobly not and maybe I'm making it a problem !!
17th Dec 2015 2:14pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Something as simple as a rubber bung missing from a hole in the bulkhead will make a massive difference. People pull them out to poke cables through for stereos, phone kits and after market towing electrics etc, Or a dislodged grommet from around existing cables is the same.
17th Dec 2015 11:22pm |
Well I'm currently buying parts to go through all the underbody rubbers , that part of the project will start over Xmas with new transmission mount and are droplinks .
18th Dec 2015 1:48am |
i think you've probably identified the problem right there then. |
18th Dec 2015 2:06pm |
Just an update for anybody thinking of adding sound deadening ...
2nd Jan 2016 11:06pm |
