![]() | Home > Maintenance & Mods (L322) > 2007 - 2012 soundproofing differences |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
I have BFG ATs fitted to my 2012 and need to cut down the noise/reverberation from the front tyres on some surfaces. The rear was fixed with stick-on similar to Dynamat lining the spare wheel well but I suspect the front guards are vibrating as they have an empty sound when tapped, unlike the dead sound from the doors. Noise from the 4.4 TDV8 is not an issue for me. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
these will help you in your quest Ian,
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Thanks for the links Stan .
i'm surprised that your engine noise is a problem, mines a 4.2 as well and the noise is acceptable.. ... - .- -.
It's probobly not and maybe I'm making it a problem !! |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Something as simple as a rubber bung missing from a hole in the bulkhead will make a massive difference. People pull them out to poke cables through for stereos, phone kits and after market towing electrics etc, Or a dislodged grommet from around existing cables is the same.
Well I'm currently buying parts to go through all the underbody rubbers , that part of the project will start over Xmas with new transmission mount and are droplinks .
i think you've probably identified the problem right there then. |
Just an update for anybody thinking of adding sound deadening ...
