Home > Technical (L322) > Keeping on top of things... |
drive2tractors Member Since: 05 Jul 2015 Location: Kent Posts: 18 |
Having managed to steer my way through some ecu/throttle problems ( http://www.fullfatrr.com/forum/topic34729.html ) I recently had another cause to use the GAP tool. Pointed to a PCV problem and having read this is a common fault, after 165000 miles it was worth investigating. I had promised myself I would do the cam cover gaskets and change spark plugs some time so today I bit the bullet and started these jobs. Used the forum wiki with much success thank goodness for fullfatrr.com!
15th Dec 2015 7:28pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Exactly the same when I did mine after only 92000 |
15th Dec 2015 10:06pm |
Reecy Member Since: 02 May 2015 Location: Southport, Lancashire Posts: 56 |
Likewise, I found mine to be the same at 92k- all fixed up now and the strange rover runs great
16th Dec 2015 1:09am |
Just a quick update: All back together on Friday with new parts, a straightforward job in the end apart from the fiddly small (5mm ish) pipe. Runs so much better, no more oil drips onto the exhaust and an improved mpg figure by at least 2! Result.
21st Dec 2015 9:36pm |
Quick update: I'm getting lambda control adaption fault codes for both banks about every 2 or 3 days. Could it be an air leak between the MAF and the throttle body? Having trouble getting this plastic tube to fit/seal properly.
30th Dec 2015 6:43pm |
