Home > Technical (L322) > Temperature guage reading high? TD6 2005 |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Unfortunately your BMW computer doesn't speak Land Rover, so while it will see most things engine, whether it understands is a different matter Land Rover did rather a good job of ensuring that only their computers would talk to the car.... they are supposed to be OBD II, but trust me they ain't
12th Dec 2015 10:16pm |
td6power Member Since: 17 Dec 2011 Location: Shropshire Posts: 5 |
Just a little update to this. Had a good drive in it yesterday with plenty of traffic / A road blasting and it sat at 3/4 the whole time. I'm pretty sure following this that its a gauge fault now.
14th Dec 2015 8:52pm |
If you brake BMW's then I don't think you'll have to look far to find a rad cap Yesterday I couldn't spell Engineer... Today I are one!
14th Dec 2015 9:26pm |
Indeed |
14th Dec 2015 10:19pm |
FYI my TD6 is running between 78 and 89 deg C when I'm not towing, and 81 to 105 when I am. Hope that gives you an idea of the temp yours should be at, the dash board will read normal from 70 all the way to 105, how much further it has to go before it says hot is any ones guess Yesterday I couldn't spell Engineer... Today I are one!
15th Dec 2015 12:43am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
If it's a pre-facelift car then you can use the secret dash menu to test the gauges and monitor the coolant temperature via the display.
15th Dec 2015 12:50am |
