Home > Technical (L322) > Temperature guage reading high? TD6 2005 |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
You could buy one of these cheap infra red temp gauges and see what the actual temp is. Match that to spec to see if you are running hot. You'll then have a better start point for troubleshooting. 2017 5.0 Autobiography Supercharged
12th Dec 2015 5:39am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
If the engine is not pressurising I would be looking at the expansion tank cap. Dont even think of using an after market one, genuine only.
12th Dec 2015 8:08am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Unfortunately this is going to be one of those answers that a new owner will not want to hear.....
12th Dec 2015 9:03am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I would suggest it definitely points to a dash/gauge/electrical issue... Some further investigation needed with diagnostics kit first before looking at engine temps/mechanical issues...
12th Dec 2015 10:29am |
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 |
Whilst I am sure my engine temp is ok , once the engine is at operating temp, My 4.2 sc gauge always reads on the lower mark , of the two marks between the blue and red sections,
12th Dec 2015 11:32am |
Ordinarily the temp gauge reads bang in the middle... That is dictated by the BCU sending it a signal which in turn has signals sent to it by your engine ECU and other sensors...
12th Dec 2015 11:44am |
So I am guessing that if it does not read bang in the middle (mine reads consistently low) , but it shows no sign of over heating , then no need to worry? |
12th Dec 2015 12:01pm |
As i said above, its easy to check the calibration of the gauge on a diagnostics tool like IID if you are concerned... |
12th Dec 2015 12:04pm |
Thanks Craig
12th Dec 2015 12:19pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Everyone goes through a panic phase a little while after joining these forums. It's wears off after a while...once all the faults have happened. Visiting from DISCO3.CO.UK
12th Dec 2015 1:00pm |
^^ Is that when you get to the "I Don't Give A " stage, or, the another fault? and? Yesterday I couldn't spell Engineer... Today I are one!
12th Dec 2015 3:18pm |
It's when you reach the "Oh, looks like the alternator's gone. Is it that time of year already?" stage.
12th Dec 2015 4:58pm |
Oh, so is there much of the original car left? Yesterday I couldn't spell Engineer... Today I are one!
12th Dec 2015 5:11pm |
Just about! Had bodywork repairs done under insurance too - new bonnet, wing, bumper, light etc. New rear prop to be ordered on Monday also.
12th Dec 2015 5:16pm |
