Home > Technical (L322) > Heater blower - only blows to footwell
awillia3
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
My range rover will only blow air to the footwell, not to face or windscreen.
I have done a fair amount of work to investigate already:
Fan speed is fine, I have taken the top of the dashboard out, radio out and cover off the blend motors to make sure both fans are working - all was ok. I also changed the FSR just in case.
Temperature is fine. Hot air and cold air can be selected and blows at desired temperature at on either side.
My question to everyone is:
Any idea where the motor is that controls the direction the air is sent? I still have the dash and the majority of the panels off so any clues would be great!!
Thank you all for reading.
Post #340714 4th Aug 2015 11:28am
awillia3
Quick update:
On top of the blend motor case there are two cables. One on left (green) and one on the right (blue).
When I select recirculate or max air con the blue cable on the right pulls the outer flap on the right open/closed and a rod pulls the same flap on the left open/closed at the same time.
The green cable on the left doesn't do anything, regardless of what buttons I press. Is this the cable that opens a flap to send air to the face/windscreen?
I have followed the cable down to the driver's side foot well and it is attached to a motor!!
Thank you!!!
Post #340723 4th Aug 2015 11:56am
awillia3
I have found this in the workshop manual:
"On both the low and high line heater assemblies, a fresh/recirculated air flap is installed in the air inlet on each side
of the heater assembly. A stepper motor drives the LH fresh/recirculated air flap and a Bowden cable transmits the
drive from the LH to the RH fresh/recirculated air flap. "
This is the cable and rod I must have seen moving. The manual then goes on to mention:
"On the high line system, a ram air flap is installed inside each
fresh/recirculated air flap. A stepper motor drives the RH ram air flap and a Bowden cable transmits the drive from the
RH to the LH ram air flap."
any ideas what the RAM air flap does?
Really stumped as to how to fix this!! Any help much appreciated. Very Happy Current:
FFRR 3.0 TD6 L322
BMW M3 E46
Gone:
2002 BMW E46 330d Estate
1997 BMW M3 Evo
1984 SIII Landrover 2.25 petrol SWB
Vauxhall Calibra 2.0i
Peugeot 205 XS
Post #340919 5th Aug 2015 8:11pm
awillia3
Also - the diagram shows three motors that control the distribution flaps - numbers 11 (RH foot well, LH face) and 15 (windscreen).
I think these may be the ones . . . gosh how to get to them??? Current:
FFRR 3.0 TD6 L322
BMW M3 E46
Gone:
1997 BMW M3 Evo
Peugeot 205 XS
Post #340922 5th Aug 2015 8:18pm
jeff64
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
hi awillia3, did you solve your problem? i have just got the same problem on my 04 td6 3.0 any advice would be very welcome. thanks jeff
Post #362081 13th Dec 2015 5:12pm
awillia3
Hi Jeff, not sorted yet. I haven't had the time to investigate further.
My next step was to take the heating control panel off to see if the motors are behind it and to see if they are faulty.
Let me know if you have any luck!! Current:
FFRR 3.0 TD6 L322
BMW M3 E46
Gone:
1997 BMW M3 Evo
Peugeot 205 XS
Post #362198 14th Dec 2015 4:10pm
sharkey964
France 2002 Range Rover SE Td6 Oslo Blue
Hi guys
I have the opposite problem,as in,all good to the screen & face.But nothing to the footwells.
Sad
Post #362202 14th Dec 2015 4:23pm
awillia3
I would rather that - windscreen needs it!!! Current:
FFRR 3.0 TD6 L322
BMW M3 E46
Gone:
1997 BMW M3 Evo
Peugeot 205 XS
Post #362205 14th Dec 2015 4:27pm
