![]() | Home > Technical (L322) > 2002/2005 FRONT DOOR LOWER BASKET TRIM FIXING HELP PLEASE |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
I recon you need a new outer trim, unless you can get all that sealant off it, then 22606, which looks like a part that fit's inside the door and grips Hs1 and Hn3...
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Thanks Peter, indeed Dan may know what I need, good idea. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
VD, the bosch wipers are 808 type, loads of info on the search.. ... - .- -.
oops typo, I meant 808 indeed, I have them on the other one. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Anyone with an idea on how to fix this trim please lads? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Just had a look on Microcat and HN1 is listed as an M6 Flange nut, so that would suggest to me that the missing link is an M6 T bolt, not an alloy pin, and you'd also require an M6 Flange nut to go with |
Thanks, this could do indeed. I guess the pin should snap on to something too.
Can you do a zoomed out picture of the broken / back bit of the trim, the whole thing not just a close up, think I have an idea of what's going wrong, I think we are both right |
External fixings are bolts, the 3 inner ones are pins. One is missing
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
could you not just stick it on with some soudal fixall There is nothing that can't be fixed with a hammer😜😜
The way the trim fits, it is a bit curved and it need the bolds to hold it, otherwise it kind of want to become straight/less curved and pops out.
Right now I see it in the full, you are missing 1 pin from right of centre and the 2 bolts from the ends that lock the whole thing in place., are you sure that there aren't any bolts (square headed) in the door panel, they would be at either end of the trim.
Clevis pin? Yesterday I couldn't spell Engineer... Today I are one!
