![]() | Home > Technical (L322) > Front end drop |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Would suspect that you've an air leak on the front, if your lucky it's a hose / union rather than the airbag..... put it in off road mode, turn off the engine when it's stabilised and have a good listen in the wheel wells for hissing sounds |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
could have leveled off if the ground is un-even...... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Funnyguy, Its absolutely NORMAL sir on a 2011 model sir... If you have an IID tool and you check the heights when running i bet the front is set a mm or two too low! This confuses 2009MY> and they lower the fronts over time periods...
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 390 ![]() ![]() |
Thank you all!! After I started it, it rose back up and has they'd there. I do not hear any hissing so all appears good! |
