Home > Technical (L322) > Front end drop
funnyguy1
United States
Front end drop
Sorry to ask this stupid question but I haven't driven my 2011 L322 in about 6 days because of snow (Michelin Latitude Diamaris great in summer, poor on ice/snow) and the front end dropped about 3". Is this normal? I started it and it raised back up. Thx in advance!
Post #361785 12th Dec 2015 12:30am
miggit
Would suspect that you've an air leak on the front, if your lucky it's a hose / union rather than the airbag..... put it in off road mode, turn off the engine when it's stabilised and have a good listen in the wheel wells for hissing sounds Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361787 12th Dec 2015 12:45am
could have leveled off if the ground is un-even...... ... - .- -.
Post #361804 12th Dec 2015 9:43am
Funnyguy, Its absolutely NORMAL sir on a 2011 model sir... If you have an IID tool and you check the heights when running i bet the front is set a mm or two too low! This confuses 2009MY> and they lower the fronts over time periods...
Obviously check for leaks as stated above “put car into off road height and listen” but if you find nothing wrong? Don’t be alarmed sir...
More than half of the later FF’s we have parked here for long periods do exactly the same! Mine included Rolling Eyes
Post #361819 12th Dec 2015 11:42am
funnyguy1
United States
Thank you all!! After I started it, it rose back up and has they'd there. I do not hear any hissing so all appears good!
Post #361857 12th Dec 2015 4:19pm
