Home > Technical (L322) > bonnet release
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
bonnet release
changed a bulb in the car this afternoon, then though oh will just do this other job, and went to open the bonnet again and the release doesn't do anything, its like the cable came off or something.
is it a simple fix you reckon??
is getting the panel off even easy Smile
Post #360708 6th Dec 2015 5:50pm
sounds like a broken cable... ... - .- -.
Post #360713 6th Dec 2015 6:07pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Do a search on here - there is a temporary fix - I seem to remember @NiceDayForIt did a write up.
If it is broken inside the car - you can remove the kick panel by driver door and access the cable - perhaps a set of mole grips will enable you to open it. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #360720 6th Dec 2015 6:48pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Easy self fix. Make sure u know which end is kaput - cable is in 2 pieces and both are separate part numbers and come together inside the bonnet space. I will warrant it has chafed at the handle inside by the drivers door!
Post #360730 6th Dec 2015 7:26pm
http://www.fullfatrr.com/forum/topic29319....nnet+cable
Post #360734 6th Dec 2015 7:39pm
stcstc31
awesome cheers
some reason i didn't find it first time
Post #360742 6th Dec 2015 8:01pm
stcstc31
got the panel off
turns out not the cable at fault
the plastic locator on the end of the handle broke, letting go of the cable
Post #360745 6th Dec 2015 8:29pm
Same just happened to mine, I just replaced the lot from Dan, new handle and bottom half of cable, it comes with the whole white plastic bit, you just need to use the screw that holds the handle on...
Wasn't much less than £25 all in if I remember right....
Tie string to the old cable under the bonnet then pull the old one through, retie string to new one and pull it through.... be careful not to pull the string off the end of the cable.... Thumbs Up Thumbs Up
Then shout at JLR for not making it in metal to start with and then you would never have had to change it.... Censored ers Pete
Post #360752 6th Dec 2015 8:47pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Had the same on my son's audi quattro earlier this year. Just the plastic bit broke, easy fix but seems all manufacturers have adopted the plastic route. Big Cry
Post #360812 7th Dec 2015 7:54am
