![]() | Home > Technical (L322) > Front headlights |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Yes & yes... Quite simple BUT!!! �150 per bulb at stealers!!! �40+ per pair on the bay of fleas |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
Thank you Craig. Will search the bay. 2011 5.0SC Santorini Black
Ok, silly question, where can I find out which bulb type I have. I can only seem to establish that the lights are xenon bulb type? 2011 5.0SC Santorini Black
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
pretty sure its a D3S type...someone with more knowledge hopefully will confirm this.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
As Stan says, looks like D3S.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i think even Halfords do them these days. |
Thank you. 2011 5.0SC Santorini Black
just to point out that there are different colour temperature xenons available..
If one bulb is on its way out, i guess the other will follow suit very soon after! Always best to have a matching pair fitted |
and they change colour with age, so even if it doesn't fail it's still best to pair them up. |
Ordered 2 today, decided to stick with the 4300K. Current ones fitted were Philips Ecostart so ordered two for 80 from amazon.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1458 ![]() ![]() |
They definitely appear whiter / blue-er, but in the wet, I find you notice they just don't quite show the road as well as the lower 4300k temp bulbs. V8 or else ... |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
They do!! Found that out a couple of months back! Offside one went, I had a replacement in the garage from when a Pheasant took out the offside indicator unit not long after we bought the car so we had to have a new headlamp as the lugs to locate the indicator unit were totalled! Replaced the offside bulb then a week later the nearside one went pop! Think it was around �60 from Halfords. |
