Home > Technical (L322) > Windscreen Trim |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
''horizontally from top of windscreen to bottom''
2nd Dec 2015 10:06am |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
LOL, yes writing on the phone , its vertical, at work at the moment so cannot take a pic, |
2nd Dec 2015 10:08am |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 |
it has 4 clips on the underside (white) and another 4 in the inside (black) if you open the doors you will see them. |
2nd Dec 2015 6:12pm |
Thanks so should not be loose then , will see if it needs tighterning or probably new clips |
2nd Dec 2015 8:23pm |
I had the same problem last week tried to refit with the old clips but didn't work so got new clips from local dealer £14 for 8 bits of plastic robbing £$%%ers, you could try the bay might be cheaper. |
2nd Dec 2015 8:49pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Ive bought trim clips from ebay in the past, they're normally cheaper, but it's hit and miss if they'll actually fit properly, a lot of the time they break more easily or they don't quite fit the holes correctly.
3rd Dec 2015 1:05am |
