![]() | Home > Technical (L322) > Windscreen Trim |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
''horizontally from top of windscreen to bottom''
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
LOL, yes writing on the phone |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
it has 4 clips on the underside (white) and another 4 in the inside (black) if you open the doors you will see them. |
Thanks so should not be loose then |
I had the same problem last week tried to refit with the old clips but didn't work so got new clips from local dealer £14 for 8 bits of plastic robbing £$%%ers, you could try the bay might be cheaper. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Ive bought trim clips from ebay in the past, they're normally cheaper, but it's hit and miss if they'll actually fit properly, a lot of the time they break more easily or they don't quite fit the holes correctly.
