Home > Technical (L322) > Failed MOT as the fog lights wont turn off !
barwik
United Kingdom 2003 Range Rover HSE Td6 Buckingham Blue
Hi .
My RR has just failed its MOt as the rear fog lights wont turn off - if the side or head lights are turned on the rear fog lights are on all the time - anyone come across this before ?
It has ungraded xenon headlights and led rear lights ( were all fitted before I bought it )
Everything normally works fine but I cant say I've noticed the fog lights on before but to late now as they wont turn off - if I disconnect the light switch they come on as well ( as do the side lights )
any ideas out there ?
regards and thanks in advance
john
Post #358803 25th Nov 2015 9:53pm
By LED rear lights do you mean the entire cluster or LED bulbs?
If it's a replacement cluster it sounds like faulty wiring as they needed some sort of adapter / relay unit
Post #358805 25th Nov 2015 9:58pm
its the led lights that are the problem....you need specific wiring and modifications to make them work properly..
i would talk to a conversion specialist who can sort it out for you...
try cam-tech-craig [site sponsor] ... - .- -.
Post #358809 25th Nov 2015 10:00pm
A few clues here if you're technically minded Thumbs Up
Post #358811 25th Nov 2015 10:04pm
barwik
Thanks for the replies - its got complete units fitted not just the led bulbs - while I was having a look my check were - turn the lights on , remove rear lights and check for power at the connectors at the rear lights - power at two points - I'm assuming one is side lights and one is fog lights so I turned everything off and put the indicator/parking light on - now I only have one live at the rear lights - so would this indicate a faulty switch ?
Post #358813 25th Nov 2015 10:05pm
They are not a straight swap - the old units were good old fashioned wiring with 12V & ground for each bulb - the new units have funky 'bus' cabling which sends instructions to the unit - so you need a conversion box of tricks to make them work properly - read the thread I linked & it gives you some idea Thumbs Up
Post #358814 25th Nov 2015 10:09pm
n1cktdv8
If you fit the upgraded 2010/2012 light units on the older cars (like I did) you need to have them configured properly - they are certainly not 'plug n play' Is this where I put the car details and a bit about myself ?........
Post #358815 25th Nov 2015 10:10pm
How long have you had the car ? I assume someone else did the conversion...... you might have to talk to them.
Post #358817 25th Nov 2015 10:10pm
barwik
Unfortunately the previous owner did the conversion assured me everything worked ! Yea right - I should have known better - I didn't expect or inspect the rear lights for working ALL the time - more surprised that it passed last years MOT as I bought it with a fresh mot !
but now its off the road till I sort it - currently I'm blinding everyone behind me !
Post #358822 25th Nov 2015 10:27pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
If it had a new MOT when you bought it were the rear lights units changed after the MOT was done? If not then I would go back to the garage who did the previous MOT and query why they passed the car with an obvious fault!
Post #358823 25th Nov 2015 10:34pm
barwik
Too late now though its over a year ago - might let off a bit of aggression but it wont get me anywhere - and it still needs sorting correctly !
Post #358827 25th Nov 2015 10:41pm
Are you able to fix wiring yourself?
Post #358835 25th Nov 2015 11:36pm
barwik
Hi.
Yea I feel reasonably confident - a diagram always helps .
Post #358853 26th Nov 2015 7:12am
steptoe
And just how do you prove the fault was there more than a year ago when they passed it ?
Post #358919 26th Nov 2015 12:52pm
Zirconblue
That would just be a waste of time, they can just say the lights were fine when they tested it, they must have been changed/gone faulty afterwards.
If you were so minded all you can do is report the garage to the DVSA (formerly VOSA) who will monitor the testing station concerned. They might send in a mystery shopper if they've had a few complaints about the same station. Sounds easy enough to miss if it was tested on a bright day and and tester hadn't seen too many L322's. I mean if it had a whole list of stuff that it should have failed on that's one thing, but for just this, it was probably just human error.
Post #358924 26th Nov 2015 1:11pm
