Home > Technical (L322) > Failed MOT as the fog lights wont turn off ! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
By LED rear lights do you mean the entire cluster or LED bulbs?
25th Nov 2015 9:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
its the led lights that are the problem....you need specific wiring and modifications to make them work properly..
25th Nov 2015 10:00pm |
A few clues here if you're technically minded |
25th Nov 2015 10:04pm |
barwik Member Since: 24 Mar 2015 Location: Lancashire Posts: 9 |
Thanks for the replies - its got complete units fitted not just the led bulbs - while I was having a look my check were - turn the lights on , remove rear lights and check for power at the connectors at the rear lights - power at two points - I'm assuming one is side lights and one is fog lights so I turned everything off and put the indicator/parking light on - now I only have one live at the rear lights - so would this indicate a faulty switch ? |
25th Nov 2015 10:05pm |
They are not a straight swap - the old units were good old fashioned wiring with 12V & ground for each bulb - the new units have funky 'bus' cabling which sends instructions to the unit - so you need a conversion box of tricks to make them work properly - read the thread I linked & it gives you some idea |
25th Nov 2015 10:09pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
If you fit the upgraded 2010/2012 light units on the older cars (like I did) you need to have them configured properly - they are certainly not 'plug n play' Is this where I put the car details and a bit about myself ?........ |
25th Nov 2015 10:10pm |
How long have you had the car ? I assume someone else did the conversion...... you might have to talk to them. |
Unfortunately the previous owner did the conversion assured me everything worked ! Yea right - I should have known better - I didn't expect or inspect the rear lights for working ALL the time - more surprised that it passed last years MOT as I bought it with a fresh mot !
25th Nov 2015 10:27pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
If it had a new MOT when you bought it were the rear lights units changed after the MOT was done? If not then I would go back to the garage who did the previous MOT and query why they passed the car with an obvious fault! |
25th Nov 2015 10:34pm |
Too late now though its over a year ago - might let off a bit of aggression but it wont get me anywhere - and it still needs sorting correctly ! |
25th Nov 2015 10:41pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Are you able to fix wiring yourself? |
25th Nov 2015 11:36pm |
Hi.
26th Nov 2015 7:12am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
And just how do you prove the fault was there more than a year ago when they passed it ? |
26th Nov 2015 12:52pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
That would just be a waste of time, they can just say the lights were fine when they tested it, they must have been changed/gone faulty afterwards. If you were so minded all you can do is report the garage to the DVSA (formerly VOSA) who will monitor the testing station concerned. They might send in a mystery shopper if they've had a few complaints about the same station. Sounds easy enough to miss if it was tested on a bright day and and tester hadn't seen too many L322's. I mean if it had a whole list of stuff that it should have failed on that's one thing, but for just this, it was probably just human error. |
26th Nov 2015 1:11pm |
