Home > Maintenance & Mods (L322) > Rear windscreen heating elements.
supershuttle
I get a bit of FM Radio interference when using the heated rear screen, its not really a problem because there is a good DAB signal around here so I normally use that until I turn the screen off - so no real problem. However the pattern (element usage) intrigues me and so on this frosty morning I took a pic you can see top right only alternate elements seem to be working for a part of the distance across, i won't fix this unless it is A. Easy and B. Free as I have a perfectly acceptable workaround, in fact I didn't even realise I had a problem until I read elsewhere on the forum about slight FM interference when using the heated rear screen
anyone got any thoughts on what and where I should check, i recently had the screen removed and refitted when the rear upper door was being replaced under the corrosion warranty Geoff
Post #358209 23rd Nov 2015 10:06am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Elements - these are usually "painted" on the inside of the screen with a conductive paint.
Something has scratched the conductive "paint" - usually you will see a thin break where the paint is missing (magnifying glass helps).
You can get some conductive silver paint from say Halfords to touch it up.
Common culprits are having something in the boot which has rubbed up against the glass and scratched off the paint.
If you find the break in one line, then it usually in a similar place on the other line if something scratched down the screen. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #358219 23rd Nov 2015 11:15am
just looked at mine and there is a element line that you can feel with your finger nail..
its possible that some connections havnt been connected properly .. ... - .- -.
Post #358223 23rd Nov 2015 11:39am
