Home > Maintenance & Mods (L322) > Rear windscreen heating elements. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3827 |
I get a bit of FM Radio interference when using the heated rear screen, its not really a problem because there is a good DAB signal around here so I normally use that until I turn the screen off - so no real problem. However the pattern (element usage) intrigues me and so on this frosty morning I took a pic you can see top right only alternate elements seem to be working for a part of the distance across, i won't fix this unless it is A. Easy and B. Free as I have a perfectly acceptable workaround, in fact I didn't even realise I had a problem until I read elsewhere on the forum about slight FM interference when using the heated rear screen
23rd Nov 2015 10:06am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Elements - these are usually "painted" on the inside of the screen with a conductive paint.
23rd Nov 2015 11:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
just looked at mine and there is a element line that you can feel with your finger nail..
23rd Nov 2015 11:39am |
