Home > Technical (L322) > 2008 FFRR TDV8 gearbox |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Gearbox is quite normal... Find that on a lot of 6 speeds...
7th Oct 2015 9:16am |
james s Member Since: 12 Mar 2015 Location: United Kingdom Posts: 10 |
Great thanks Craig. Good to know about the box - it does feel very odd, particularly 2-3, then fine all day!
7th Oct 2015 9:19am |
Either buy an IID tool? Or find someone with a multi use one? Of buy an updated bt module?
7th Oct 2015 9:38am |
Many thanks Craig. If I were a bit nearer to Dursely I'd book it in, but as I'm in Marlow its not really practical. I'll have a word with our local specialists and see if they can do it. - thanks again.
17th Nov 2015 3:32pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
The phone problem might be where you have stored your contacts if they are on your SIM card they can't be read but if they are on your phones memory then they can be L322 2008 vogue
17th Nov 2015 7:51pm |
Thanks Ivor- its intermittent. Sometimes its OK, sometimes the directory won't work. The names are there but it won't find them. When a number is selected it won't call - just goes back to the initial phone screen. Same if selected from received or sent calls |
17th Nov 2015 9:49pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1391 |
Mine is a bit temperamental sometimes as well. I think it greatly depends on how clean your contact list is on the phone. If its a mix mash of sim and phone memory contacts as mentioned before, then it doesn't seem to display them all that well. V8 or else ... |
17th Nov 2015 10:22pm |
