![]() | Home > General > Buying a high mileage TD6 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Gearbox is definitely questionable at that mileage, so I'd get proof it's been repaired/replaced. Got - 2017 SDV8 Autobiography in Loire Blue
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8372 ![]() ![]() ![]() |
Air bags, shocks, suspension bushes, subframe bushes, steering rack, wheel bearings, drive shafts, propshafts are some other items to think about...
Brake pipes will also need checking, especially where hidden away under plastic covers
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
That sort of mileage is getting in to second gearbox territory let alone first, I can't see any way that is the original box. The biggest problem is if you drive them softly, Miss Daisy, at 30-50 mph that is prime torque converter slip speed, and will cause it to wear out quicker than at say 65 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
Mines at 131k and still doesn't use any oil or water. Front suspension air bags done though.
The first ffrr I drove was a 2005 with 127K, it had been chipped and drove fine, so I thought......... The second ffrr I drove had done 95K was unchipped, smoother, more power and a lot quieter than the 2005, so I brought it |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
My 04 TD6 is on 171k and still has original box |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
My 04 is on 130K, original box with 80% been towing horsebox with 2 up! The rest of the car however is another story...... |
I agree Miggit, although mine has "bucked the trend" for the OPs benefit I would't buy one without gearbox history |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
150K on my 2004 and I have paperwork showing all sorts from headlight wiper blades and arms, a front left air shock that was done in 2010 the right one gave out on me last month so I replaced both (to be sure) It also had all the injectors replaced at a cost of well over £2000 a few years ago although I suspect that may have been dodgy fuel (a lot of it about these parts!) other bills are for normal servicing and stuff like gas struts (tailgate) and the odd bulb here and there. Car is driving fine, most electric bits seem to work, gearbox is smooth and transfer box engages and disengages smoothly and Hill descent does what it is supposed to.
Brian, you can sort the clock by pulling the fuse and putting it in at 12 O'clock, resets the clock to 12. Pete was going on about it in the Fitting an Android head unit thread, near the end P 25-27 |
Sort of remembered that but keep forgetting |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Lots of good advice here.
