Home > Maintenance & Mods (L322) > Service menu on MY11 TDV8
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Can someone point me in the right direction?
Trying to check the oil level on a TDV8 MY11 4.4.
Embarassed Embarrassingly, I can't see the dipstick.. The handbook says its all done via the service menu in the cab on the TFT - great, no need to get oiley.
The first thing it says is to switch on the ignition without starting the engine, and access the service menu - How do you do that? I cant get the ignition on without starting the engine, and the service menu is greyed out.
Many thanks,
Dave __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #357063 15th Nov 2015 2:29pm
found this ,
Turn ignition on
PRESS the Right hand directional button on the steering wheel to access the instrument cluster menu
the service menu will appear
PRESS the right hand button OK to confirm
PRESS the Right hand directional button on the steering wheel to ACCESS the OIL LEVEL DISPLAY
PRESS the Right hand OK button & follow the instructions
PRESS the CRUISE CONTROL CANCEL BUTTON TWICE WITHIN 2 SECONDS
this will
The message center display will revert to the normal display in the trip computer
Check the oil level display shows an OIL LEVEL READING
but it doesnt say how to switch on the ignition without the engine starting.... ... - .- -.
Post #357071 15th Nov 2015 2:50pm
Is it not a case of keeping feet off pedals and press start button to switch ignition on without starting engine
Post #357072 15th Nov 2015 2:52pm
DaveAngel
Awesome, thanks both - was driving me insane! __________________
2015 FFRR SDV8
Post #357076 15th Nov 2015 3:05pm
Yes, don't press the brake,
Puts the start button
Access the menu
To check the oil level the engine should be warm on the 4.4, it also won't display a reading if the engine hasn't sat for long enough after switching off.
So basically after a run park it up wait 10-15 mins then take the reading. There is nothing that can't be fixed with a hammer😜😜
Post #357331 16th Nov 2015 9:41pm
