Home > In Car Electronics (L322) > Fuses td6 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
14th Nov 2015 1:31pm |
There's a rubber bung in the bottom of the compartment where all the modules sit, you can remove it to let the water out again.
14th Nov 2015 2:40pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
Amazingly spare wheel well is dry, possibly the last couple of days weather has done the damage. Any links to a new seal or is it LR only item. |
14th Nov 2015 2:45pm |
The seal is LR only, best place to get is via Dan@Duckworths, forum sponsor. Just send him pm with your requirements. |
14th Nov 2015 3:01pm |
Had a good look today and it turns out the tailgate seal is OK, water has been getting in thru the side trim so i have removed it fitted new clips and sealed it, all seems to be ok now after 20 mins of hose pipe abuse. |
16th Nov 2015 3:40pm |
Latest update, Being a stubborn old sod i thought i would have another go at it today. I stripped the tv/entertainment unit and solder two wires to the PCB, then connected them to the loom the other side of the blue connector. And hey presto we have a monitor again. Next job is the radio, got it working but only for 5 mins ( switch it off and then on it works for another 5 mins ) I will keep at it |
27th Nov 2015 3:55pm |
Apart from the three plug in connectors on the amp i noticed there is a aerial type connector should this have something connected to it ?? |
17th Dec 2015 5:57pm |
How do i establish if my amp is the problem OR the BM54 radio tuner to my no noise music system?? Help please |
17th Dec 2015 8:33pm |
Although there is an aerial connector on the DSP unit nothing is connected to it.
18th Dec 2015 10:31am |
Cheers niceday for your reply. im going to attack it again today, no doubt more help will be needed Thanks Brian. |
18th Dec 2015 10:39am |
DSP is not coming up on screen, does anyone know to a amp for sale? |
18th Dec 2015 11:28am |
Have you tried taking the casing off the DSP and looking for water damage on the rear of the sockets on the top.
18th Dec 2015 12:57pm |
Yes i have had it apart and all seems good and clean inside no sign of water |
18th Dec 2015 1:05pm |
http://www.fullfatrr.com/forum/topic30365....eplace+dsp I find that a little hard to follow |
18th Dec 2015 1:12pm |
