![]() | Home > In Car Electronics (L322) > Fuses td6 |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Could some one advise me to which fuse controls td6 indicators please. |
Thank you for your prompt reply. Well i jumped in the old girl this morning and noticed i had no radio ( not the end of the world ) Then when i reached the end of the road and indicated i noticed no indicators. So i thought fuse maybe |
You could try disconnecting the battery for a few minutes and see what happens.
Thanks for your advice, will try the battery idea and report back. Regards Brian. |
Tried disconnecting the battery. no change im afraid. Will see what tomorrow brings |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
I had that happen to me as well, check in the back where the amp and other bits are i found it was down to water ingress gone fishin' |
No sign of water anywhere nice and dry |
Do your hazard warning lights work? |
Yes they do |
That tends to suggest to me that you have a fault connected with the column switch for the indicators.
I did notice the hazards were silent and the two green lights in the instrument cluster are not flashing either when the hazards are on. I do appreciate your help and time on the matter. Looks like time to get the tools out. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Had the same issue a few years ago - disconnected the amp etc in the rear and cleaned all contacts with a fibre glass pencil - put back together and all has been well since. |
Well done Merc, I have just been hunting for the amp which i presume is the black block under the sat nav. Gave the leads a wiggle and hey presto all works again. |
