Home > Technical (L322) > Repaired - Can't find this eas problem using search: |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8205 |
Sounds about right, I'd confirm the split before replacing, and as the shock is integral with the strut you should change them in pairs... Delphi are OEM, Dunlops apparently don't last as long.... Pete
13th Nov 2015 6:15pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
It's been standing now for a couple of hours and you can push the bag in with your thumb about half inch (the others are solid). I've tried the soapy water but can't see any bubbles. Is there anywhere else where air can leak out affecting just one air bag?
13th Nov 2015 6:32pm |
The struts are not connected to each other usually so it will be somewhere on the bag or in the pipe from the front valve which is at the rear of the drivers wheel arch. The hole could be in the fold of the bag and leaking very slowly so you won't hear it and bubbles could take some time to show themselves, start the engine, take it up to off road height and try the soapy water. Pete
13th Nov 2015 8:58pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
As Haylands says.
13th Nov 2015 9:15pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
My front O/S bag has a leak, initiallly hard to find, but after a few days got worse. If I raise the car to off-road height, I can hear air hissing out of the centre of the strut. have just bought 2 new Delphi units from Dan @ Duckworths, Island are quoting £249.50 + vat, Dan did them for £225 + vat 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
13th Nov 2015 11:07pm |
Bought two struts from Paddocks, £258 each (Delphis). Turned out near side had been done about 2 years ago (before I bought it) but was a Dunlop (will sell this on the bay of e). Offside was original, so now waiting for the rears to go
17th Nov 2015 8:17pm |
Rears last much longer than fronts, mine is still on the originals... (jinxed them now though )
17th Nov 2015 8:24pm |
That's nice to know, could do with a bit of a rest from repairs - especially as it's now cold and wet
17th Nov 2015 8:31pm |
"cold and wet".... aaarrr that'll be new alternator and battery then..... Pete
17th Nov 2015 11:30pm |
