Home > Maintenance & Mods (L322) > Getting flashed
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Getting flashed
Ok not that sort of flashed - I am getting fed up at the moment with other drivers flashing their lights at me at night because they think I have full beam on (which I don't). Usual response is a choice word under my breath and a flash of my lights to show them what full beam is really like
Does anyone else get this happening to them a lot os is it just me....
Ok rant over. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #356416 12th Nov 2015 12:39pm
I used to get that until I had my headlights adjusted - they were pointing too high Thumbs Up
Post #356419 12th Nov 2015 12:48pm
wealy
Me too.
Adjusted them myself, and it stopped straight away, not really noticed the difference in lost light on dipped, and I live down a very dark country lane!
Post #356422 12th Nov 2015 12:54pm
common problem on the newer FF's mr P...
you can adjust downwards a bit..
http://www.fullfatrr.com/forum/topic33756.html?highlight=flashed ... - .- -.
Post #356427 12th Nov 2015 1:06pm
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I used the continental adapter flappy thing to flatten off the headlights not a problem since I did it.
Post #356447 12th Nov 2015 2:03pm
^ +1 and MOT legal too Thumbs Up Thumbs Up Thumbs Up
Post #356458 12th Nov 2015 2:18pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Hi what do you mean please ?
My Xenon on the drivers side is to high, I used the Allen key adjustor but doesn't drop the beam enough Many thanks
Paul
Post #356498 12th Nov 2015 6:21pm
are you adjusting the correct screw?
Post #356506 12th Nov 2015 7:05pm
Pvw10
Thanks Stan
I adjusted with my lights on against a fence so I could see the moving light, the Allen screw dropped the beam but only so far, then the adjuster screw just clicked and began the same cycle against
Looking at your great diagram I think I altered B which if horizontal would make me think I had the correct one as would drop the beam a little so think your right, I will check.
Thankyou Many thanks
Paul
Post #356508 12th Nov 2015 7:12pm
have you adaptive headlights, if so that one might be faulty....other than that you might have to have it dealer aligned.. ... - .- -.
Post #356510 12th Nov 2015 7:18pm
Pvw10
I just edited my last reply, I think you have sorted it for me Smile Many thanks
Paul
Post #356511 12th Nov 2015 7:19pm
nice one Thumbs Up ... - .- -.
Post #356512 12th Nov 2015 7:21pm
MrP
Thanks all for the info
I will have a look tomorrow and adjust them down a little "On first name terms with my local Dealer......now."
Post #356568 12th Nov 2015 10:59pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Mine ARE correctly adjusted, but it doesn't stop people continually flashing Big Cry so I just flash the main beams back at them, blister their eyeballs and convince them I WAS on dipped beam Twisted Evil
Trouble is, the headlights on a FF are so bloody good Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #356595 13th Nov 2015 6:32am
wealy
They are simply too high.
You think they are OK as they are in spec and you know they are on dipped. They are probably border line in spec and an oncoming sports car or low sitting driver has the discomfort of your selfishness and curses all 4x4 drivers.
If you adjust them very slightly downwards you will not suffer very much in lost vision but you will stop oncoming flashers!
Post #356602 13th Nov 2015 8:31am
