![]() | Home > Maintenance & Mods (L322) > Bosch Aero Retrofit blades? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Miggit,
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I bought a set as well, not fitted yet as its being blowing a gale here.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
from the wiper arm there is Ian, mentioned a few posts back... ... - .- -.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I think it depends on which wiper arms you have. If you have the hook type them maybe not as it seems you just open the plastic fitting and hook them in. If you have the type described above then you need to squeeze together the two sides of the plastic fitting and completely remove it from the metal arm before clipping in the new blade. 2012 5.0L S/C
And all of this from the drivers side ![]() ![]() You will then be left with this
Simples ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! Last edited by miggit on 21st Nov 2017 12:53am. Edited 1 time in total |
Fitted mine last night, dead easy 2 minutes for passenger side and about 4 minutes for driver side which is harder because of the spoiler getting in the way.
Just drove mine in light rain. Still a light thump at the end of each swipe but nowhere near as bad as the clunk on the old ones. |
They are not totally silent at the top of their travel, but they also aren't maddeningly deafening either |
Mine arrived, fitted with no problems but they still clunk as much as the Bosch 808s did, not really any quieter unless its different at speed.... Discovery 4 HSE
^^ can you hear it over the radio at start up volume, assuming that it comes quirt at the same level regardless of the ear bleeding level it was switched off at |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
So come on chaps, what is the approved (or your) method for separating the original fitting from the arm, everyone says it was a PITA to do, but no-one describes exactly how? Does one "simply" prise it out by levering on the sides of the arm?
The N/S (passenger) ones are easy, remove the old blade and just squeeze the plastic in to the middle and it will free it's self. It should be the same for the drivers side, BUT, the aerofoil makes it all rather rigid, and the fact that it's stuck in the middle of the windscreen doesn't help either. In hindsight it would be an advantage to do the N/S first, then operate the wipers and stop them at the top of their travel, which would then make the drivers easy to get at, |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
When I got my FF the wipers clunked maddeningly as described. I fitted Bosch 808 nineteen months ago and they make no noise at all. Surprised that people are reporting noise. Wonder if it is down to adjustment of the arms rather than the blades? John
Thanks Miggit, tomorrows job |
