Home > Wheels & Tyres > Spare Wheel |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 |
Yep, mine has 22s and spare fits no problem. I'm guessing it's not the lightest of things but hopefully if you ever need it you might get someone to give you a lift |
5th Nov 2015 9:23pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
They fit
5th Nov 2015 10:33pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
I was specifically warned, by my Indy, when searching for a car, to check the spare wheel is the same size as the ones on the car.
6th Nov 2015 3:17am |
^ Yes, but the rolling diameter will be the same regardless of rim size. a 19" could still be used as a spare without issues as long as it uses the same nuts as the 22's on the car. |
6th Nov 2015 7:33am |
StevoJD Member Since: 01 Mar 2015 Location: Worcester Posts: 29 |
Oh, so now I'm confused.
6th Nov 2015 10:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
just regard the 19'' the same as a space saver wheel, fit it [if needed] to get you home...
6th Nov 2015 10:13am |
Easily. Plenty of calculators online. This was a quick shufty I managed. Different rims require different profiles of tyre, hence the RR (rolling radius) remains relatively constant. Remember, the profile number is a percentage of the width of the tyre so if you increase width without reducing profile the RR gets bigger. |
6th Nov 2015 10:34am |
Fantastic, thank you chaps. |
6th Nov 2015 2:18pm |
So, just when I thought I could use the 19" wheel as a spare it turns out that the studs don't line up, it's obviously not going to work.
7th Nov 2015 2:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
The 22” 405 tyre measures 275 40 22 sir |
7th Nov 2015 2:56pm |
So, does anyone have a 22" rim or a space saver spare for an L405 for a reasonable price?
8th Nov 2015 7:27pm |
Any particular style ?
8th Nov 2015 8:03pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
As has been mentioned, its the overall rolling diameter that is important. e.g. a big wheel with a low profile tyre can have the same diameter as a smaller wheel with a fatter tyre.
10th Nov 2015 7:26pm |
Yep, but I've seen plenty of non standard sizes Craig. Generally the 22's tend to be 265s but I've also seen 285/35/22 tyres fitted. As I said, there are plenty of calculators online which would give an equivalent rolling radius for a different sized rim. That said, my OCD made me change my space saver for an identical 20" rim bought from a member on here. |
10th Nov 2015 8:17pm |
