Home > Maintenance & Mods (L322) > WARNING change your diff oil!!!
Page 9 of 10 <12345678910>
pld118
1.5L is the quoted refill amount. When doing our SC last year, 1.5L came out and 1.5L went back in, no issues at all.
Post #355917 8th Nov 2015 10:34pm
Zirconblue
Are you sure the car is completely level? Even if the suspension is a bit low at the back it would do it.
Post #355918 8th Nov 2015 10:44pm
pld118
Did it exactly same a last time. Back end was raised via jacks and axle stands!
Post #355920 8th Nov 2015 10:55pm
pld118
Concerns now allayed:
Car had been driven briefly since the drain and refill yesterday. Both fill and drain plugs were bone dry on inspection today (not that I expected any leaks). I then removed the rear diff filler plug and once out, there was not one drop of oil streaming out of the hole, as there had been when I got to the last 0.1L of the refill yesterday. Re torqued the filler plug and now happy, job done well, all in accordance with manufacturer's spec (interestingly, when removing the fill plug today, the car was only in off road height with no axle stands or jacks being used and it was facing the other way round in our garage... I wonder if uneven level yesterday was in fact causing it all) Thumbs Up
Also changed the Transfer Case fluid today. Such an easy to access and easy to do job. 1.4 came out and 1.5L of new TF0753 fluid went back in. The old fluid looked ok but when compared to the new fluid it was indeed a tad murkier and not as golden looking Thumbs Up
Front diff oil to be changed next when chance allows. The manual says that when raised, the front wheels should be turned to ensure that all oil is given the chance to escape via the drain hole. How do you rotate the wheels when the car is only on 2 axle stands at the front end. Is it a case of chalking the rear wheels, leaving the car in neutral and ensuring there is ground clearance for both front wheels so you can then safely rotate them and free up all oil?
Thanks Thumbs Up
Post #355970 9th Nov 2015 3:51pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
I did my front and rear Diffs last week at 61k. The front wasn't too bad but the back stank awful and was full of glitter. Is this normal or is it a sign of excessive wear?
Gary
Post #356241 11th Nov 2015 12:06pm
the only way to find out is to check it in a few months time...if its gone glittery then you might have a problem, if clear then its ok .. ... - .- -.
Post #356247 11th Nov 2015 12:52pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Cam-Tech-Craig wrote:
Adam, its not tremendously thick oil like you would be used to in a Defender! More like expensive engine oil consistency... So no real need to warm it too much pal... Thumbs Up
Oil in a Defender? Rolling with laughter
................most of it leaks out!
Post #356252 11th Nov 2015 1:13pm
pld118
Garyfax wrote:
I did my ... Diffs last week... the back stank awful and was full of glitter. Is this normal or is it a sign of excessive wear?
The purpose of a good magentic drain plug is that metal particles floating around can stick to it and can save on wear and tear that such particles might cause. You can buy so called stronger magnetic drain plugs from the likes of Opie Oils et al. I replaced the drain plugs with a new LR supplied one but others on the forum don't always bother replacing the plug.
The oil in the rear diff stinks and has done so on the two occasions I've done it. The first time, I changed the rear diff oil on our 4.2SC @ 88k miles/ 7 years old. It was a horrible, dark glossy brown colour. No water mixed in and no metal particles floating around, nor accumulated on the magentic drain plug. The second time was on our 4.4TDV8 @ 30k miles. It was almost the colour of new oil but a tad darker. No water mixed in there and no particles accumulated on the drain plug magnet, although there were some very fine/ very early signs of metal particles within the drained fluid.
People say that if the Diff has been affected by wear, symptoms can also include a metallic whine noise, which Ive never experienced.
Post #356266 11th Nov 2015 3:08pm
Garyfax
Thanks PDL118. My diff runs very smooth and is quiet, I was just concerned about the glitter which was all the way through the oil. I wish I had taken a pic now to put it on here. I'm going to change it again in a few thousand mile to see how it looks. If it's still same I will strip it down and inspect the gears.
Post #356912 14th Nov 2015 5:53pm
pld118
I commented yday on a long drive that the car seemed smoother after changing diff oils and transfer case fluid but probably in my imagination!
Post #356931 14th Nov 2015 7:30pm
pld118
L405 Diff Oil
Presumably the L405 Diff oil needs to be changed at similar intervals as the L322?
Is the procedure the same/ anyone done it on the L405?
Our SDV6 build sheet says the car has 'Rear Axle Open Style Differential'
Thanks
Post #454882 22nd Oct 2017 8:23am
GGDR
Just reading this, can anyone recommend an Indy in the South East that can do diffs TC and trans fluids?
Craig you're a bit far for me otherwise I'd be over to you!
Greg Cheers, Greg
Post #454885 22nd Oct 2017 8:57am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Re: L405 Diff Oil
Thanks
Hey Fella - I cant stress how simple it is to do:
Front & Rear Diff oils - total time is about 20 mins max each - oil costs around £19.00 per litre ( only use Castrol Syntrax Long Life 75W90 Synthetic Gear Oil - no other make !
Transfer box - again this is 20 mins top - so easy I got the wife to do it last time !
Going to your question: As its so simple to do and as LR recommends every 75,000 miles - I do ours cars very 20,000 miles - its a no brainier and costs so little to do. JUST ENSURE you only use NEW copper LR washers - especially of the Transfer box Drain and Fill plugs - and TORQUE to correct settings.
NOTE: and this is a big note - ALWAYS undo the FILL PLUG first BEFORE the DRAIN PLUG - if for any reason the FILL PLUG will not undo then at least you still have the oil in the unit and not all is lost !
That said a well maintained RR is a pleasure to work on.
Another word of caution - NEVER OVER FILL ANYTHING as this will lead to catastrophic damage.
if in doubt always get the fluid levels in writing from your LR parts department then you know that's the bible.
If anyone reading this about the TRANSFER BOX OIL: ONLY USE LR IYK500010
No other oil ever use in the Transfer Box - its a very special thin grade oil - I change ours every 20,000 miles - its so easy to do
Post #454899 22nd Oct 2017 11:17am
GGDR
EmiratesA380, great info! I am contemplating doing this myself so great to get an idea of what's involved - and some excellent tips too.
What kind of tools would I need? You mentioned torque wrench. Anything else?
Greg Cheers, Greg
Post #454904 22nd Oct 2017 11:43am
EmiratesA380
Hey Greg
If you give me a day I will do a write up step by step of what you need to do 1. Transfer Box 2. Diff units
One point to note now - Is never work under neath a Rangie with only the suspension set to max - this is not safe as as you are aware the air suspension can lower to access height at any time ( I do not trust having the divers door left open - as this should disarm the suspension from lowering.
That said - I would suggest ( like I do ) - is purchasing 4 railway sleepers - I drive the car onto these - so its already a foot high - then I raise the whole car on the max suspension - that way you are safe under the car ( as long its the railway sleepers on on flat level ground.
The Rangie is easy to drive onto the railway sleepers in a straight line - just ensure the wheels are mid center on the railway sleepers. - try not to work under neath any car on your own - 2 is always best
A full write up will follow for your usage.
Hope you fly Emirates soon -
Post #454907 22nd Oct 2017 12:01pm
